Anyone tried using the new power supply from Temple Audio? It is 24 volts providing 65 watts of power and 2.7 A. I think using that, paired with a Cioks Crux set at 12 volts to would work to power the QC and would be the cleanest, simplest power solution (and maybe cheapest?) to power the QC. It is only one power out, so if you have more pedals then you would obviously need a bigger power supply, but if you’re only using the QC and an expression pedal, this seems like the way to go!
While I switched to a battery powered system, I previously ran the QC, an active expression pedal, and a Wireless receiver with The CIOKS Hi5 (the Temple Audio, specific power supply), and the Crux.
Worked flawlessly.
I have a Strymon Zuma R300 I used on a bigger board, and I know I can use the 24V out on it to the Cioks Crux to power the QC, but it’s a bit overkill for a Temple Audio Solo 18 only running the QC and a passive expression pedal.
I ordered the Temple power here https://www.templeaudio.com/guides/65PSU_Setup_Guide.pdf that I think will work with the Crux and a pretty simple solution.
I am curious, what batter power system are you using?
I totally agree, the 65W power supply driving the CRUX seems to be the cleanest and simplest solution with CIOKS components. This avoids the need for stacking Flex cables across multiple outputs to power the QC.
Optionally, you could add in the Hi5 mod which has a 24V pass-through. In that case, you would go 24V from the power supply to the Hi5, then 24V from the Hi5 over to the CRUX. This gives you five spare power connections on the Hi5 for pedals, LED lights, USB port, etc.
One other variation worth mentioning is with the Strymon PS-124 instead of the Temple Audio 65W power supply. Both provide 24VDC via EIAJ-05. The Strymon is roughly $10 less ($39 vs. $49 in US) and slightly more compact (4.2″ x 2.2″ x 1.3” vs. 4.6" x 2.2" x 1.4"). The main downside of the PS-124 is that it is lower power (24W). It could only power the QC/CRUX; anything else would be pushing it. If you think you might want to add in the Hi5 in the future, I would stick with the Temple Audio 65W supply (which is what I did).
If you want to go ultra low cost (under $20 total) and compact, there is discussion in another forum thread regarding a lower cost power brick + adapter cable. You would need to find your own mounting solution (e.g., Dual Lock) but it could work if you only need to power the QC.
Hi there, I am planning to buy a Cioks DC7 to power my QC and Lehle Dual Expression but I was wondering about this option. Could you share a pic of how you set up the connections? Thanks bro.
Sure! So I’m just running the QC with an expression pedal as well, so no other powered pedals on my board. I am running the Temple Audio Amp Mod on the board as a power amp to run to cabs.
I’m using the Temple Audio 65 watt Power Brick, a cable runs from it into the Cioks Crux, and the out of the Crux is plugged into the QC. There is an IEC splitter that connects power to the Temple Audio Power Brick and another Power Brick I got from Amazon to power the Amp Mod. It’s not the “cleanest” looking setup underneath, but with a small space there isn’t much you can. Plus, it’s underneath and I just don’t care that much
. I love this setup though. One cable to power the board, one cable for guitar, and one cable to the speaker cab (or 2 if I want to run stereo cabs).
