Describe your issue:
I have Mission Engineering EP-1 pedal and I’ve plugged it into QC and assigned it properly. I’m trying to play fast, rhythmic things with whammy block. Problem is that the whammy doesn’t seem to have the time to go up all the way, while my leg is already going down. To put it simply, the whammy (or the expression pedal in whole) has real bad latency problem. Problem doesn’t show in slow tempo, but fast tempos you can catch the latency of the pitch easily.
Use expression pedal with QC and assign it to Wham block
Play fast tempo rhythmic music and rock the exp pedal in tempo
Notice the latency between leg and pitch
I expected this to happen:
I expected the expression pedal have no or as little latency as possible.
I experienced this as well, especially noticed this for Wahs. I am using a Dunlop DVP3 Pedal.
I also think that the knob value of the assigned parameter visually lags behind a bit.
When looking into the expression configuration in the input/output menu (swipe down) the visual feedback seems to be more in-time.
Not tried it with Wah but I have noticed some parameters lag more than others. This week I tried my Boss FV500L assigned to master on the amp sim and it lagged. If I assigned to Output - no lag…
Fingers crossed it’s software based and an easy fix… although my return port indicator still shows something plugged into it despite no cable plugged in so where this latency would fall in their list of priorities no one knows…
Please send us a ticket to support@neuraldsp.com, in case you haven’t already. It would be great if you could include a short video example showing the latency between the pedal and the parameter.
I am also experiencing the same issue, exactly as you described it. Everything in my setup is connected and calibrated as it is supposed to be and I even took it a step further and did a side by side comparison with my actual Digitech Whammy pedal and it was a night and day difference between the two in terms of pedal response/latency. This is a big concern of mine with my QC, however, for the time being, I have the real pedals to substitute in. I’m looking forward to the update that corrects the issue. I too am following Gonzalo’s advice/request and submitting a support ticket with video, but I’ve been in the middle of remodeling my studio space and haven’t been able to get everything hooked up to shoot a quick vid. In due time I suppose. They will get it worked out for us I’m sure.
+1 on the latency of the Pedal when assigned to wah. It’s always behind the pedal moved and just not usable. This unit is getting increasingly frustrating …
I have this same issue. I first discovered it when I was moving multiple parameters in an Eq block to try and get close to a custom Wah sound for fun. The latency made it unusable. I went back to the standard Wah block and it was better but still obvious latency when playing fast Wah pieces. It becomes very obvious when you compare to a real Wah, which is immediate as you would expect.
Any assignable parameter to the expression pedal needs to be very very low latency for best feel.
I still use it in a pinch as the auto engage is very useful and the actual Wah sounds are great, so hopefully the latency is just a software update to fix.
Same issue here, most noticeable with Whammy. If i try to go up and down fast with the pedal the Whammy effect has a slight delay, i can’t really use it to play fast up and downs pitch shifts. I’m on a Mission SP-1 expression pedal.
I thought the latest update was supposed to fix this.
I’m still experiencing the same latency.
I have calibrated the pedals over and over.
I plug the same pedals into a Boss processor and it is instantaneous.
Not sure how to measure this, but it must be at least 10ms. It just feels laggy.
I was hoping for a solution with a QC and a couple of expression pedals.
The lag is killing my groove.
Hope they can fix it.
Expression pedal latency is still very notable, especially on the WHAMMY. The whammy block is not nearly as responsive and quick as the DT WHAMMY PEDAL.
Would love to use the onboard qc whammy but cannot since it has a lag of pitch shifting and many digital artifacts with chords compared to the digitech pedal.
I am on the latest firmware.
Please update the latency further and whammy block for more clear and quick expression use.
I have this same issue with two separate expression pedals and multiple different TRS cables on OS 1.2.2. This includes the recommended mission engineering pedal. Please can you reduce this latency!
I also have the mission engineering ep-1 and there is noticeable latency with wah and whammy even though I’ve calibrated the pedal. I’m also on the latest firmware. It’s not terrible but it’s enough to be slightly annoying.
I use a volume pedal all the time and this latency is killing my groove.
Pedal steel swells and just normal volume up and down are a little behind.
Obviously I can put a volume pedal in front of the QC, but I was hoping for an “in the box” solution.
Not sure how to document the lag.
Maybe a video of the pedal and the QC screen, split views and locked?
Just bought another pedal to test it and the result was the same.
Asking Santa Neural for the gift of pedal accuracy.
