I have noticed there is considerable latency when using an expression pedal. I tested it out with a wah pedal, and was pretty disappointed.
I used the Axe FX 2 for a while with an FCB1010 through MIDI, and its expression pedals had too much latency for me. When using the pedal jack with a 1/4" out expression pedal, it works great with virtually no latency on the Axe 2. I was hoping for the same, but sadly I think I will be returning my Quad Cortex. It was so close to being great.
I put together this short video demonstrating the difference in response times.
My patch on each unit is just an amp/cab with a wah pedal in front - expression pedal controlling the wah at full 0-100. I am utilizing the dual out exp pedal so I do not have to replug it in.
I am going for a quick burst to the highest point in the wah’s motion precisely on the attack of each note. So you should hear (lets say the wah goes ‘wwwooooeeeeaaaahh’) the “aahh” part on the downbeat. With the quad cortex example, by the time the downbeat strikes, you are still hearing the “wwwoooeee” part as it catches up to my movements.
If you quickly switch back and forth between the AxeFX 2 example and the QC example, you should hear the difference pretty blantantly
The PodXT Live had a better pedal function than this
Yes, I have noticed the same thing. I am using a Roland EV-5 pedal. I will test to see if the issue only applies when the pedal is running the wah. It will be interesting to see if there is the same lag when the pedal is mapped to another parameter like volume or pitch.
I also have notice pretty nasty latency when using the expression pedal for whammy pedal stuff. Like bordering on unusable. It’s still an incredible unit, no chance I’d send it back, but would be great if support could get on this! Will they read here, or do we need to raise a ticket somewhere?
I would like to contribute to this discussion. I too have noticed the expression pedal latency, so far, while using the Whammy effect. I found it to be quite disappointing. I really hope they come up with a software update to correct the issue. I was so looking forward to selling my Digitech Whammy pedal…
That being said, I’m willing to exercise patience with the development of the QC. I just hope that they get this issue worked out before I start gigging again.
Has this been resolved?
I just got my Quad Cortex after waiting 5 months but if I cant use the wah or whammy theres no reason to keep it. I find the latency to be too much for wah and whammy use. I don’t see myself carrying arroung the Quad Cortex, a wah pedal, a whammy and a expression pedal just to make it work. For swells, volume or fx mix it’s not that big of a deal.
Yes, I confirm, there is a delay. It’s not comfortable to play. This needs to be corrected, a big blunder. Competitors do not have this, so this is a software problem.
I think they just built the hardware wrong - If they had taken this into consideration seriously at all they would have studied older units and replicated the expression pedal implementation - I think they are afraid to admit that it can’t be fixed.
Of course it can be fixed. I really don’t think there can be anything physical (analog) delaying the expression signal, any latency must be digital and therefore a software (or firmware) issue.
I have the feeling (difficult to measure) that the delay depends on the parameter and device the expression pedal is assigned to.
That also hints for a software issue.
