On the Fractal Audio FM3, you can have four channels per block. You can have different Virtual Devices per channel allowing you to switch between different amps, cabs, drive pedals etc., per Scene.
This is super helpful as you do not have to add multiple amp, cab or any other Virtual Device blocks if you are only using one at a time.
Definitely missing this feature on the QC vs my AxeFx… Have two of them, gotten really used to having channels on a modeling device… setting up multichannel presets on the Quad is a bit challenging at times.
For this you have eight scenes in the QC, which can have completely different settings of the block parameters. The AX-FX cannot do that, that’s why the channels exist. The only disadvantage is that, for example, in contrast to the Channels, you cannot change the amp per scene in an amp block, but you can insert several amp blocks or captures into the grid.
Agreed, but I am not referring to just amp or cab blocks. On the Fractal, I can have four channels for every block. Do I really want to add 2-3 amp blocks, cab blocks, drive blocks, or anything else where a particular Virtual Device type is not a good fit for every scene? Not really.
Scenes do not fully compensate for the lack of channels the Axe has both Scenes and channels for example. The two features compliment one another…
The lack of channels on the QC makes it really difficult to switch amps within a preset without duplicating effects or settings, for example. Especially when its omission is combined with how the QC partitions the DSP on a ‘per row’ basis which requires you to rearranges blocks in the layout based on their DSP cost.
This would be a really nice feature. Didn’t get if with current firmware 2.0 it’s possible to have different amps on different scenes using one single amp block.
there’s been no indication that NDSP is considering doing that.
Best bet is to keep publicizing this feature request to try to catch their attention- this one is pretty low re: popularity
Other requests exist. I realize this one is originally from March 2021 and has the most votes; I’m only posting this to demonstrate that a lot of people have the same idea. I would use this feature.
This is years later, but the Cortex absolutely needs this feature. I miss it from my Fractal hear. So much easier having completely different amps/drives in the same block.
The VP4 uses this to great effect (pun intended). You only have four switches, but tap-hold on a single effect brings up 4 different variations that you can then swap to with a tap. Very elegant way to get multiple flavors of an effect within one scene or preset.
having been in the fractal eco system for the past 10 years, I’d agree this would be nice to have here on my QCM, however its not a deal breaker for me…
Having tried Fractal stuff and done a lot of research into their UI, I’ll say this was such a confusing element of their setup.
It could be helpful for the amp to just have one block that can switch channels without gaps, instead of loading separate blocks for the clean/distortion channels of a head. But I understand why no other modelers really do it like Fractal. Fractal loves menu diving for everything and it’s so confusing. Their UI and menu systems have to be one of the worst and most convoluted out there as far as usability.
Just reviving this as I became a new QC owner and a former Fractal user.
Yes, the Block channel was one of my favorite features from the FAS. The fact that their least powerful unit can run up to 4 amp models in the same preset with a single block is definitely a good thing to think about. I used to have a couple of presets with param-EQ as a DI shape for each of my 3 different guitars. So instead of having 3 blocks for the param-EQ, only 1 with 3 configured channels.
