Capture block with channels
since captures take up so little resources, the ability to have a capture block on the grid with multiple captures loaded in it that you can select which one is active per scene, or select through them with switches. just to free up more grid space. one capture block with different captures in it, run them internally in series or parallel, toggle through them, or bypass the whole container
