Add Virtual Control variable
Currently you can tap a block on The Grid, access its contextual menu, and select Assign Expression Pedal and Assign either Exp 1 or 2 to control a parameter.
Could you add 8 virtual controllers to this list that can be controlled from the rotary encoders. Then in gig view you could assign a virtual controller to one of the rotary encoders. This would make gig view way more powerful and enable the users favourite parameters to be changed extremely quickly. If the virtual controllers also had midi CC numbers it would increase their usability.
Several requests already exist for assigning block parameters to the rotary switches.
Please utilize the search function prior to submitting new requests. Thanks!
