I’m surprised I can’t assign almost any parameter to a switch, and surprised there aren’t more toggle options. Morningstar FX midi controllers are fantastic. The same switch can be used a variety of ways to control parameters.(Single tap, double tap, short press, long press etc) Quad cortex would be unstoppable if the same kind of flexibility was possible.
It would be very practical to toggle between 1/8 and dotted 1/8 delays for example. Or adjust the mix or feedback between two settings.
Or to have a dual amp set up and toggle between the two amps like a typical A/B/Y. You can do this with an expression pedal, but not a switch? Would be a great feature.
