Use twist buttons as assignable expression
hi!! i’m sure i’m not the first to this but would it be considered in the future to make the twistknob foot switches assignable like you would and expression pedal. it would be awesome to keep delay time and repeats on dedicated knobs on the unit that i could bend over and manipulate like a memory man or dl4!! then in stomp mode there’s just like little text for what button is also assigned to whatever parameter (drive level, delay time et cetera)
thanks!
Brilliant! I can think of instant uses for this.
there are a lot of Feature Requests for assigning parameters to switches, it might be better to find one of those and add your votes to what’s already cast.
this one seems to have the most, but there are a few others that should probably be merged together to maximize the requests
sure thing thank you!
