Assign parameters (bass, gain, atack como, mix reverb… Etc) to the switches with minimum values (switch disabled - enabled) and maximum (switch enabled - disabled).
This can be done with scenes, but two switches are required to set minimum and maximum values.
With this suggestion, only one switch is required.
