WiFi help needed
How can the WiFi/QC connection be improved?
The QC operates on the 2.4 GHz band, so make sure your network is either running in 2.4 GHz or mixed 2.4/5 GHz mode. Furthermore, the QC needs a connection strength of –60 dBm or higher to work properly.
Do not include special characters in your network name (SSID).
Reserve a static IP address for the QC in your router settings.
Many routers have an option for setting device priorities. Set the QC’s static IP address to “High Priority” or “Realtime Prioritization.”
When running the network in mixed mode, choose different SSID names for the 2.4 and 5 GHz bands.
If you are using a mobile device as a hotspot, turn on the “Maximize Compatibility” option.
