I just discovered the side-chaining available in the Adaptive gate .
Currently i’m using Adaptive gate without S/C in front of the amp.
I will try asap the S /C after the amp.
What is your experience with noise gate in the QC and feedback. Prefered one?
The input block gate/noise reduction is also an option so it is difficult to guess wich one is most effective.
I’m using High gain amp EVH red 6L6 without a boost and i’m pretty satisfied with Adaptive gate so far, but some new Intel would be great.
Thanks
Adaptive gate with S/C after the amp is the way to go. If you want to clean up some hand noise, etc you can either add the input gate or another gate before the amp.
A good idea is to automate the gate to change with certain scenes. I don’t mind adaptive gate with S/C being on during cleans sometimes, but will turn off any other stronger gates when using a clean amp. The gate after the amp is awesome to cut out amp hiss (yes even for cleans).
I think the adaptive gate could be used for specific purposes but it doesn’t suit me for my playing. I just use a regular gate after the amp. I like to roll down the volume of my guitar so any gate before the amp tends to cut off the signal. For metal with abrupt stops, gates before the amp or with the activator before the amp would work great. Also, I set the gate at the lowest possible level, turning my volume down on the guitar and ensuring I won’t get drop outs. I would say I give the gates in the QC a C+. They are workable, but not the best I have tried.
It was a sigh of relief when sidechaining got included in the QC. I use adaptive gate after high gain blocks and sidechain to the input, just like you’re describing. Works great for me.
I tried Adaptive gate S/C after the amp and it is good. With Input 1 triggering.
I use the input gain at 40%, and the Adaptive Gate at 0%.
I managed to switch off the input gate via Scene ,when going lead sound. And it works fine for me.
Adaptive gate before the amp was less effective.
Now it is more ressemblant to what i had with the Zuul Mini, after my Engl Head.
Anyone know how he’s doing it ? He seems to have some great results. (I’m personnaly not interested into taking the pack, sounds are quite nice but doesn’t interest me that much especially that i don’t own those plugins)
He is using a splitter and sends specific frequency range to the second line and use a gate there. But I don´t know how he achieves the best result which ends up a selleable product:)
Hello, everyone. With the latest update, I noticed two details. Firstly, there is a significant increase in sound output. The presets are producing seriously loud sounds. The other issue is that the background noise has increased considerably. I also tested it on a device that hasn’t downloaded the update yet. The difference is significant. Whenever I create a preset with high gain or download a pre-made one, I have to use multiple noise gates. Is anyone else experiencing this issue?
Almost exclusively using the Zuul.
With CorOS 3, we got the Zuul from the Nameless plugin suite and the Adaptive Gate. I’m not sure why they wouldn’t have added sidechaining capabilities to the Zuul version. I think the Adaptive gate after the amp with Input 1 as the sidechain might be better than the included Zuul.
I’ve also gone down a bit of a rabbit hole on this. I want tight stops but then also decreased noise after the amp. I have the Zuul from the plugin and obviously all the other gates. Which gates should be used where and what is everyone generally using? Also what’s the difference between the utility gate and the adaptive gate or the input gate? Why does the Zuul not have a sidechain? I think this needs a much needed video from NDSP explaining how each is typically used. Separately, with Misha plugin, the horizon devices pedal also has a gate, so how to throw that in as well?
