Which Expression Pedal to use
Ok so I’m using a passive Bloomery Pedal with a dedicated tuner/expression output but the sensitivity of this thing with the NC trying to control things like Wah or Gain is almost impossible. It goes from basically nothing to almost full on. Its a 25 k pot so it should work. and I set it up properly in the Cloud app. What is everyone else using successfully?
Anyone? Any success story’s out here concerning expression pedals?
I have a Boss EV30 dual expression, which works great. I need the additional expression control for my DAW control. I used to use an old Roland EV-5.
Thanks appreciate it!
Dunlop Volume(X) Mini - DVP4 works for me.
Thanks. I did manage to slow the response a bit with the only expression pedal I have. I’m starting to think it might be a tweak needed for the NC down the road. The taper is just way too fast and renders an expression pedal almost useless, IMO. What do you think?
Roland EV-5 expression pedal works for me.
