CorOS Version: 1.1.0
Describe your issue:
When configuring Whammy effect, depending on what I want to achieve, that either the heel or the toe is the original signal, and engaging the expression pedal triggers the increase or decrease of the pitch to the amount desired.
The issue is that when setting 0 semitones for one of either positions (toe or heel), the signal is still being altered by the whammy algorithm.
The expected behavior was that at 0 semitones the signal would be the same as having the effect bypassed.
