Pitch Shifter - add "whammy" style linear shifting
The pitch shifter is working great on the QC, but when it is paired with an expression pedal, the shifting is “quantized” to semi-tone steps.
While it makes sense when you need a fixed pitch shift, having linear control over the pitch shifter when using an expression pedal, and thus making the change in pitch smooth like a slide, will be ideal.
There’s a separate whammy model that does this
