Hello! Apologies if this has already been asked. I was wondering if there is a way to use the QC to switch channels on a Mesa Mark V 35 combo? There is a MIDI footswitch input on the back of the amp but after some research it looks like its not actually MIDI. I saw a video where the guitarist was able to do this exact thing utilizing this cable but he was using a helix. He plugged it in to the amp out of the helix into the Mesa Mark V. I was wondering how this translates to the QC or if it would even be possible to do with the QC? Thanks in advance! Best-Tronics Mfg., Inc. > Mesa Amp Cables > Mesa Mark V:35 Switching Cable
Some of the Helix stuff has a dedicated output for amplifier switching. If you’re using the quad cortex you’ll need different cabling (if it will even work). The midi for QC is super limited, but it might be able to send midi messages to a box like this to change channels. This might be the answer for you-
I use the Midi Matrix to switch channels on my Mark V. Little bit of a learning curve but once you get it, it works great!
