Hi all,
I’m currently using an RJM PBC 6X to MIDI control my Quad Cortex Scenes via footswitches in a way that a single QC Preset would be a song, and the scenes are the different amp models I’m bypassing/engaging throughout a song for different tones i.e. Clean, FX Heavy, OD etc.
The issue I’m running into is that I have the right CC command to select the scenes I’ve matched to each footswitch on the PBC, but no matter what the QC is insistent on having to go back through whichever scene I saved on last within that preset.
For example:
I saved on Scene A in the Preset.
I can seamlessly switch From Scene A to any other scene.
QC forces signal to go back to Scene A if I try go from any other Scene to another i.e. Scene E to B.
QC only will give seamless switching if I switch to Scene A then go to my other desired Scene, which is essentially what it is forcing itself to do anyway and is resulting in the multiple amps/stomps of One scene > Scene A > To the next Scene with  those sounds blaring through the output before settling to the right Scene.
This could be the same deal no matter what Scene I last saved on, be it A to H, it will always quickly flash to its ‘home-base’ then go to the correct Scene I had programmed to select.
Is there anyway to disable tis feature that the QC wishes to default to its last saved on Scene? I’m sure there are people out there who have used a MIDI foot controller with the QC and not had this issue, as this swapping through signal chains rapidly is just as useful as the pause in sound loading entire presets.
