Switching preset in DAW
How would I go about to switch presets within a DAW on a track? I want to avoid having a 2nd or more instances of the plugins (using Reaper and Nolly/Abasi)
I found something out… I made a midi track that routes to the Nolly VST. I can set there MSB/LSB and program. No matter what MSB/LSB I set, the value I send as program, changes the treble dial of the Nolly amp (No.2). Looks like some weird midi implementation :wink:
Hi @lars.oeschey. Archetype: Nolly doesn’t have full MIDI implementation yet, but it will have it in the near future. For Archetype: Abasi, you can try the method described on this thread. Just make sure to use the VST2 format.
ok, thanks, will try to switch to Abasi then… I thought all plugins share some kind of generic midi library :wink: Oh, and I use VST2 only anyway, already had some fun trying to physically switch some other VST3 plugin and failed just because of VST3 (takes a while to find out)
