I would like to use two pitch blocks in parallel after the amp/speaker to create those nice 80s big hair rock sounds. It works, but it seems really buggy and strange.
I create a split/mix line after the amp/speaker and drop in two pitch blocks. One block in the first line and one block in the splitter line. Both blocks are parallel and last in the signal chain. I assign one switch to each block. So far so good. I can switch both blocks in and out with no sound change and no volume drop.
When I then set one block to a few cents negativ and the other to a few cents positive I get a great chorus like sound, but without the modulation. But switching both blocks in and out now creates a considerable volume drop. Not good.
The strange thing is, that when I set the shift back to zero in both blocks it sounds like the amp is in a box with a cocked wah in the signal chain. Very strange.
When I reset the blocks to their default values, I can recreate the whole procedure from the start …
Is it me not seeing something or is this just plain buggy behaviour ?
Cheers, Todde
