Cant test this because i only have 1 cab. But if my delay is stereo before the cab and the cab is mono, will multi out spit mono?
From what I know, putting a mono block after a stereo block will colapse the output to mono. So it should work yes, unless the cab block specifically doesn’t behave this way.
EDIT: now I get it that you’re talking about a physical cab not a cab block on the QC. QC outputs doesn’t automatically convert to mono if just one cable is connected. You need to either just choose that output on the output block or add a mono “dummy” block (something mono that doesn’t alter the sound/volumes/tone) after the delay so it would colapse to mono.
