Hi all,
Is there a way I can get a dual delay on Quad Cortex in which the tempo is the same but the subdivisions are different? I’m running the QC in 4 cable method mono throug a Series FX loop.
Interesting. Any idea?
Well…two mono delay blocks, both with sync enabled. Apart from CPU load, there’s not limit to the iterations count of a particular block on the QC. You could chain 10 delay blocks if you want to.
In the end I realized it’s easier than I thought. I just put a mono out at the end of the chain (ie only output 1 and not multiple) and the dual sounds in mono.
