I assume there isn’t - but is there any risk leaving the QC plugged in 24/7 in standby? It seems to get fairly warm even in this mode which would suggest a fair amount of power usage. I wouldn’t want to prematurely kill anything
Here are some thoughts about this: Standby vs. Shutdown?
Personally, I would at least shut it down over night.
I usually leave mine on 24x7x365, unless its being moved etc., I keep mine on standby pretty much all the time since I purchased about a year ago.
Mine stays on all the time, in standby. I’ll unplug when electrical storms are predicted, but otherwise it stays plugged in and in standby when not in use.
The “Standby” mode is not putting the device into a deep sleep. It seem to switch off the screen and that’s it.
Mem: 185804K used, 35648K free, 136K shrd, 10628K buff, 57296K cached
CPU: 2% usr 6% sys 0% nic 89% idle 0% io 0% irq 0% sirq
Load average: 4.19 2.26 0.92 1/74 1771
PID PPID USER STAT VSZ %VSZ %CPU COMMAND
640 1 root S 270m 125% 5% ./ZenUI -qws
But I guess you need to measure the power consumption on the power supply unit to determinate if the is any significant difference between standby and normal operation without any workload.
@ danimaetrix But so if you observed that the device is getting still warm there will be no real/good standby at all.
For all who let the device 24/7 running - at best with the wifi connection/internet connection: well, congratulation ! you are rich ! ![]()
P.S. these are the CPU speed values (MHz) in standby mode:
# cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
450000
# cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
450000
# cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_min_freq
112500
cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_available_frequencies
450000 225000 112500
Also from this point it seems that the cpu will not go down to the lowest frequency in standby mode.
But power consumption is not only a question of CPU - I guess also the rest of the hardware runs full power in standby and will not be powered off.
It is an odd unit:
Power on uses 22 watts, normal operation 16, but standby uses 13, so it’s not really a standby - it just turns the screen off.
I reckon it’ll cost around £50 a year to leave on permanent standby.
these are awesome data @audioinfected - how did you obtain it? Are you able to access the QC root system??
Based on this thread, I’m definitely turning it off now if I don’t plan to keep using it for the day. It really was suspiciously warm for something supposedly in what I thought was a sleep mode.
I think standby mode shuts the screen down and disables the I/O to prevent pops etc., going to PAs, mixers, FRFR, FOH etc.
Can haz root shell?! Enquiring minds must know!
Hi Xush:
It uses 13 watts in “standby” (normal operation uses 16 w) so that’s around £50 a year, about to increase to more like £75… or £100… or…
And… even when turned “off” it uses 1.3 watts.
when turned off it’s probably the power adapter consuming energy. This happens with most I think
Hi Danimaetrix
The unit consumes 1.3 watts when off because it doesn’t have a ‘Proper’ on/off switch but an electronic one. If you disconnect its power lead the external psu consumption drops to zero.
I don’t worry about the cost, which is either small, or negligible to me. As far as the equipment goes, I subscribe to the belief that turning electronic equipment ON is more stressful than letting it run continuously.
I let my desktop computers run 24/7/365 and there has never been a problem.
desktop computers are designed to run 24/7 and modern platforms include a lot of self management and error correcting behavior to maintain their state along with much more advance solid state storage. I’m not saying the QC doesn’t, but I highly doubt any level of stress incurred due to switching on and off will increase the risk of failure. It is after all, a pedal unit. That’s literally what it’s designed for.
Also, the unit runs on a standard micro SD card. Letting it run continuously will potentially shorten the life of that card owing to the continuous read/write process.
