Standalone fine - VST intermittant static - Mixcraft 9 Pro
Standalone works perfect.
The loaded VST works fine except for occasional (sometimes a lot) static ‘noise’.
Tried everything I can. Being able to adjust the audio controls in the standalone
was nice - any way to do this within the VST???
Hey @EL84_Abuser. Your DAW should have a similar tab to configure your audio settings (could be at File > Preferences > Sound Device). Be sure to replicate the same settings as the Standalone, or try going for 44100 Hz / 128 samples.
If you’re experiencing performance issues, check these guides depending on your operating system: Win / macOS.
Please keep in mind that currently, we do not support Mixcraft: https://neuraldsp.com/faq/
Thank you very much for the response!
@EL84_Abuser No problem!
