Hello all, was wondering if anyone else has experienced this and knows how to fix it. I’m using Presonus Studio One and every time I open a Plini instance, there’s ear-splittingly loud static - I can’t figure out how to stop it, I’ve tried changing the volume of the default setting but it won’t save. I just forget sometimes and it’s extra bad when I’m using headphones. Any ideas?
I typically use 96k - turns out that it happens at anything 88k and above, but I’d prefer to use 96k for more detail. Any idea on how to fix this?
We are aware that some users experience similar behavior with Archetype: Plini on projects with a 96kHz sample rate. Our development team is already working on this issue.
Apologies for any inconvenience caused.
Thanks for the response, glad that it’s in the process of being updated!
Just a quick update - I realized that it only happens when turning on the Reverb. If the Reverb is off, then there’s no static. Not sure if that could help the dev team, but it something to be aware of.
Thank you. I’ll let them know.
