Solution for sound gap when changing between pedal switches presets
If you use the same post fx options across presets, I’ve found this solves the sound gap issue. I’ve found that if I use the same delay and reverb fx across all 4 pedal buttons, there is no gap when changing among them and I even get tails when changing between presets with different settings or expression pedal positions. I am also able to choose from different pre fx options without a gap, so one preset has a wah pedal assigned to the expression and 2 others are assigned to the wet levels for reverb and delay. also 3 of my pedal assignments share the same amp NAM while the 4th is unique and this doesn’t seem to cause a gap. The only sound issue I have is when switching from a preset that has a volume pedal assigned to the expression pedal to one that doesn’t and I hear a brief “tch” sound, which I haven’t found to be a major issue. Hope this helps those that are frustrated by this issue. The disadvantage is the limitation of choices for time based wet fx, but for me this isn’t a problem, as its the same as most of my pedalboards where a single pedal filled the role.
I use the same fx options on all my bass presets which are compresssors and EQ’s. I still have the gap switching going on. It isn’t instant like a normal pedal.
