MIDI : Preset change with small delay along with popping
Hi
For the last week I have been trying to resolve this problem without success.
I have the Nano Cortex connected via midi (Boss ES-8), when changing presets there is always a delay accompanied by a small click.
Although small, when it is amplified, as the objective is to pass through the amplifier’s power amp, it is completely unusable compared to any other pedal connected in the same way.
I don’t know if anyone else has seen this problem.
In normal use as a pedal there is no problem but when controlled by midi there is, in fact, this major setback.
I hope it can be solved with an update, otherwise the main objective of having the Nano Cortex is completely incompatible with the rest of the equipment.
Sorry for the length of the text in advance, but I’m completely stuck with this and I have a few gigs coming up.
Thank you for your feedback and understanding
Thanks …
Hi SLPedro,
I was searching the forum to find an answer about gapless switching between presets via MIDI and found your topic.
Having not yet pulled the trigger for the nanocortex, this is THE feature I need in order to incorporate the unit in my existing rig, but as I read your lines, I understand gapless switching seems to be restricted to the unit’s footswitches :frowning:
Hope gapless switching will be added to MIDI preset switching soon :pray:
it indeed should :slight_smile: fingers crossed
