Just wondering if there’s a recommended way of setting levels for both single coil and humbucker guitars? I don’t use hot pickups but I am finding my les Paul is making the jazz chorus preset overdrive. I’d appreciate any help as I am finding it difficult to get a nice clean sound with humbuckers.
The best way I’ve found is to throw a utility gain block in front of the amp which allows you to reduce the level hitting the amp. You can save the different settings as a scene or preset or you can adjust it on the fly if you wish. I use this approach with a few of my presets, going back & forth between a Tele, Strat, and EBMM JP6.
