Hi everyone, is it possible to use the mvave chocolate (non plus version) in nano cortex via usb c and also be able to use the expression pedal via trs?
The non plus version is not a host so I am not sure if this also works.
Thank you in advance
No, that wont work. At least my Chocolate (non plus) doesn´t.
Moreover: it wont even work with the wireless dongle that you can buy with the original Chocolate, which actually has host function. Some hosts doesn´t work with the Nano. For instance, The Luminite Graviton M1 doesn´t work either.
Replying to myself: the Luminite M1 usb host works if you do a weird cycle (set “device “, restart, set “host”, restart) every time you start it up, as a user told me.
BUT, Luminite sent me a prototype PCB to replace the original one (because, before I ordered mine, he told me wrongly that the host feature worked with the Nano Cortex, and when We saw it didn’t, he offered me a refund or getting updates to try while he researched for a solution… which is what I chose). With this PCB, the M1 works perfectly without the need of doing strange settings changes nor restarts.
Absolutely recommended. Luminite is great.
