Reverb on/off in IR loader to save CPU
Would be great to be able to completely disengage this with on/off parameter. This was actually picked up by someone else when they noticed you can load more IRs with cab blocks than IR loaders. I assume it’s due to the room reverb in the IR loader.
I don’t understand what value-add including a reverb in the IR loader has. The IR Loader sound better to me than reassigning IRs in the Cab block and they’re sooo much easier to use, but I can now only run 3-4 IR Loaders on a row due to CPU use. Stop combining functionalities please.
Yeah i don’t get it either. There’s other ways to make “room sound” already.
I agree that reverb should be optional in the IR Loader blocks…
But while I saw the same limitation as you concerning the IR Loader block when I tried to use them instead of a bunch of Cab blocks (switching them on/off with scenes) , I noticed that the IR Loader block can use scene parameter on the IR file !
Now, I only use 1 IR Loader block on my preset, and the Scenes dynamically change the IR used in the IR Loader. (I don’t do it really often , but while there can be some latency, it doesn’t cut the sound)
are you saying you change change the IRs in the loader per scene? if so, cool!
Yep !
I was a ‘Holy F🤯ck’ moment when I discovered it ! Really cool feature (that should be advertised, imho)
I’ll do my best to spread the word. That’s pretty cool
Sweet! Scene parms to the rescue. Thanks!
Changing impulses via Scenes also works in the Cab block.
So i need only one cab block in my presets and use an integrated cab in clean passages and my own impulses in my HiGain sounds.
I never saw that page of the IR Loader block. Can you turn it off competitively?
