REQ USB Audio Matrix Mixer
Request:
A matrix mixer for the QC USB audio channels.
Use case:
QC mono mix Row1 out MainOutL and USBout1 to computer.
Processed computer mix of USBout1 back to QC into Row2 set to USBin1.
QC mono mix Row2 out MainOutL (or any other QC output)
Today the routing variants for multiout are not flexible enough.
Instead of adding more variants
a matrix mixer like it is found in RME Audio TotalMix is used
to be able to do any possible routing and store it in the preset/bank/setlist.
The RME hardware does not produce sound itself like the QC does, this is more simple.
So for the QC mixer, the computer must know about and reflect the choosen configuration on the QC.
You’re right, the multi-out should be more flexible.
For example, live I used 4 inputs rooted to 6 outputs. I would love to be able to record the separate tracks via USB while maintaining the analog multi-out to send the different tracks to the sound engineer
Hi, if this request fits your needs you could vote for it…
