waht about the change between vol and wah in this one? can i go 100% volume without changing to the wah?
Hi , 5 years later m’y question is… What câble do you use to contmect you Dunlop pedale to the QC.
I have one VP Jr and would like to use it to change between 2 scenes using the “Midi-bump-hack”"
thanks
I’ve used the M-Audio EXP-1 and a modded CryBaby (10K linear pot wired to a TRS jack, setup for auto-return/always going back to heel position), and currently use a Dunlop DVP5 Volume(X)8. All three have worked perfectly, just make sure you’re using a TRS cable.
The DVP5 is a great choice as it’s exactly the same size as the QC, only downside (if you need one) is it doesn’t have the toe switch (but I didn’t want one, so there’s that).
