I was in error, sorry. The UniVibe is not missing.
The Dual Chorus seems to drop the level if placed after the cab near the end of the signal chain. I would vote for an additional volume level in this block.
A dedicated volume block would be nice to have too. Just to add a volume boost wherever you like in the chain.
And if the switches could be assigned to more than one block at the same time, I could turn on flat EQ with a slight volume boost together with the chorus in order to level out the volume drop âŚ
Yep, Iâm using the gain block now ⌠works great. Hadnât considered it before because I associated âgainâ with distortion like in an amp and not with level.
A digital replica of the Mesa Boogie Five-band Graphic Equalizer
with the frequencies 80 Hz, 240 Hz, 750 Hz, 2.2 kHz and 6.6 kHz
with a gain of +/- 12 dB
An âunassign allâ would be nice instead of having to do each change individually. Or, a simple double tap on the âABCD square iconâ to unassign it.
The sends and returns are TRS right? Is it possible to have each input and output to work in stereo for more routing option. Basically this would allow to have 4 external pedals with y insert cables.
Stomp mode able to change multiple blocks or parameters from a single switch. For example, swapping between two amp blocks with one press. Or changing 3 parameters (high/low) on an amp block with one press.
The ability to blend/mix the Odâs. I use them to add more bottom or tighten the amp. But sometimes it takes away from what you like from the original sound so a mix knob would be great to blend original sound with OD sound, to taste.
It would be nice to be able to change the impedance in individual scenes or presets.
I found that itâs not very convenient to use an external fuzz. There are two options - use it in front of the QC, or through a FX loop.
In the first case, this makes it impossible to use the noise gate before the fuze.
In the second case, you need to change the impedance at the input to a suitable one for the fuzz. But then you wonât be able to switch from fuzz to something else, because again itâs necessary to change the impedance and the impedance settings are global.
Better sounding modulations, reverbs (especially spring) and delays.
Verellen stopped making amps recently and I was considering getting one, so seeing a Verellen amp sim or some good captures of a Skyhammer and a Meat Smoke would be awesome. If youâve never heard these amps I believe Serial Hawk recorded with them. If youâve got one please capture it and upload.
(re) A synth block would be very useful (polyphonic better).
The little Boss Sy-1 can do the job, why not this mega-powered QC ?
Even if there is only the remaining DSP power for a simple âclassicâ chain : dist/amp/delay/verb !
