How to control the Quad cortex with the m-vave chocolate in scene mode? ![]()
Good question. I can not seem to get mine to work at all. All help or advice would be appreciated ![]()
I use the QC in stomp mode and assigned 4 scenes to M-vave chocolate. Therefore I have 12 switches to use on stage.
You first need to download the CubeSuit app to your mobile and tie your M-vave to your mobile via bluetooth. Then open the app and go to “advanced custom mode”. You will see 4 blocks like “Foot Switch A” and B, C and D.
If you want to assign the Scene A to the 1st footswitch of m-vave you need to press “Foot switch [A]” then type “CC#43 0” then it will control the Scene A. (43 means scenes, and 0 means the first scene. It starts with zero, so goes like 0,1,2,3,4,5,6,7)
I’m currently using 4 scenes as E, F, G and H. So I typed below data to each 4 one in the app.
CC#43 4
CC#43 5
CC#43 6
CC#43 7
I hope I could make it clear. If not I can try with screenshots or videos etc. Just let me know.
BTW, m-vave chocolate doesn’t let you use the F and G options by pressing 2 switches at once. But there is a new one called “chocolate plus”. I heard that you can use them either, so that way you can use 6 scenes instead of 4. I’m planning to buy and try the plus version.
I don’t use stomp mode
It doesn’t matter. You can use QC in scene mode, instructions are same as I have written.
ok, i’ll try
Thank’s
So if I add two chocolates I control the eight
Great question. I would like to know how to set it up if its possible.
You can setup short press and long press for button ABCD. So you can have 8 senses from chocolate. It s all on the app, you just need play it on app.
I think 2 chocolates will not work as eventually you need to plug one to midi port of QC (with wire or wireless). Options might be like ;
- Using short and long presses to expand possibilities with normal chocolate
- Using group switches to use F and G with chocolate plus
- Using another brand with more switches (e.g. morning star). There are many brands available in the market.
I didn’t know about this first function, here in Brazil there is no video explaining it.
I will try to find this configuration. Thanks
Since you can’t configure the MWAVE to use stomps + scenes mode, I can think of a way to use the MWAVE, but I don’t know if it will work:
1.- Configure the QC in Mixed mode (4 scenes (ABCD) and 4 stomps).
2.- Configure the MWAVE with the 4 missing scenes (EFGH).
Do you think it will work?
This will definetely work. I use the M-vave to control scenes EFGH already. This is my habit left from the days that I used to use it in hybrid mode, top 4 stomps bottom 4 scenes. Now using the QC all in stomp mode, but your prediction is correct.
Do u have tried to configure the Chocolate to change between Stomp & Scene modes?
I know that should be
CC#47 2 for Stomp
CC#47 1 for Scene
but i can’t figure to made it to work!
Sorry but I don’t have any idea about mode changes. I wanted to change scenes and nice people on forum helped me out how to figure out, that’s only thing I know about that midi stuff
I was totally ignorant about that.
Keep asking, here and also use Facebook group. I’m sure someone will help through.
I can’t find the app…can anyone help? Thank you
I don’t know why but it’s only available on their web site. You can go into by your phone and download CUBESUIT as an app apk and it runs smooth.
