I just bought the m-vave chocolate to use with the nano cortex, it works very well, but you can’t select more than 32 captures. The problem is that the last captures I have taken, with the NC, of the 33-57 are the best since you are gaining experience and you know which ones to get off the cloud and which ones not to. I can’t assign them a switch with the chocolate, since it only goes up to 8d. Does anyone know how I could do it? Or can the nano cortex presets be changed in order? Until now I have not achieved it.
Thank you.
The chocolate has 8 banks with 4 buttons each, so I can only assign one switch for the first 32 presets of the NC. Does anyone have the solution to be able to load the remaining 32?
Thank you.
Hello friend, how are you? I’m having the same problem with the M-wave Chocolate. I don’t understand why we can’t organize the presets in the order we want. It forces you to erase everything from the factory and build everything from scratch. Very bad on Neural’s part, let’s hope they correct that in future updates. Is there any way to make this problem known to the brand itself?
I tried to connect the Nano Cortex with M-Vave Chocolate with a TRS patch cable, connecting the Pedal output of the Chocolate to the Exp/MIDI input of the Nano Cortex. It does not work. What cable are you using?
Have you seen this video? I hope it helps. https://youtu.be/LvnIVyMbZ-I?si=rBT6Ia46oWMbwMvy
Hi Blue, yes, thanks! The author was so kind to help me out on FB. I was stuck on the setting: you can only do them via computer, not on iPhone or iPad. Also, my Mac was not installing the app due to restrictions. I had to do some workaround.
Do you know how one can set up the Chocolate to control the scenes instead of the presets?
I believe you can only do presets on the Nano but they are gapless so you can just set them up like scenes.
