Quad Cortex "forgets" Expression Bypass settings between patch changes
Trying to use an expression pedal for a low pass filter.
Regardless of what the BYPASS setting is, when I change preset and go back into it, it forgets it and I have to set it up again and it’ll remember and work fine until I change patch again.
Super strange and extremely annoying. Doesn’t matter what it is, STOP, SWITCH, HEEL TOE - it doesn’t work.
Actually that’s not true. For WAH it seems to be OK. But I want to use it on an envelope filter and tremelo and its not working. The block doesnt light up until i reconfigure the setting, then it works fine. But then if I was to then save and change the patch and come back, it’s gone again.
Anyone want to try it to see if you get this issue?
Set up the envelop filter or Love Meat. Assign expression pedal. Change the Level or Freq or Reso settings to use X1 or X2 depending on where your expression pedal is. Test to see it works when you step on it and move it up and down. Change the bypass to anything. Test to see it works. Save patch. Go to another. Come back to it.
Or is it just me?
For future references, this is a known bug that will be addressed in future updates but also:
WAH Bypass with Expression pedal does not work after restart - Quad Cortex / Bug Reports - Neural DSP
Solution at bottom seemed to work for me.
:slight_smile:
