Cannot get an expression pedal to switch a block’s bypass or mute as I would like. Cannot reverse the polarity of a bypass when trying to set this up. It does what it wants. Thoughts?
Example: would like my expression pedal to bypass or mute the wah and activate a boost block when in the heel position. Both are bypassed/muted at heel and both come online when I push the pedal.
When I try to toggle one or the other manually to get them out of sync with each other, the bypass button literally changes back after I lift my finger.
Thanks. Tried all that. To no avail. Both tweaks have limited application for the bypass assignment options.
Currently using a work-around that actually sounds okay: using a splitter, reversing the min/max ranges and tweaking the min to cause Send To B (boost block) to go from unity to zero as I depress the pedal into wah. IIRC. In the heal position it’s full boost and the wah mutes.
I guess I should report the bypass/mute inflexibility when assigning the expression pedal as a bug.
