Im using a factory preset in scene mode and would like to change the volume for a specific scene. When i do this it changes all the scenes to that volume. How can i change the volume of 1 scene without effecting the others?
Check out page 52 of the manual:
Scene Bypass State Behavior
(Settings > Device Options)
This feature controls whether
changes to the bypass state
of a block in Scene Mode are
automatically saved to the
active Scene. By default, all the
changes are overwritten.
Note that you cannot modify factory presets, you must do a SAVE AS and save to your own presets.
Thanks for the fast response. I disabled scene bypass and its still not working but i will keep trying to figire it out.
Is changing the volume considered modifying the scene?
you need to save the preset as a User preset, the changes won’t stick to a Factory Preset.
Then, long-press on the volume parameter you want to change between scenes. The small ABCD icon will appear. Now any changes you make are ‘per-scene,’ only that one scene will be affected. The others will remain as they were.
Now save the preset for these changes to persist.
This worked thank you!
@xush beat me to it! ![]()
You may have missed my note at the bottom of my last post:
