I am still learning this fantastic Quad Cortex. I downloaded a sound from the Cortex Cloud Zwreck 20, and I am trying to set up scenes. But for some reason, every time I make an adjustment and try to save it to a scene, it saves it for ALL. I open a stock preset like the Swiss Knife, and I can set up scenes, make changes, and save them to the scene. I am missing a step here with my new sound. Any thoughts? Please and thank you.
Thank you for your response. That appears to be a global setting, which is set correctly or set to default. Strangely, this isn’t happening to all presets.
sounds like the opposite of what should be happening; a factory preset shouldn’t be editable unless you’re doing as ‘save as’ and creating a duplicate elsewhere.
User presets DL’d from the Cloud should be editable in all cases.
Maybe you have a bug? Have you rebooted the unit several times since the last update? Have you tried Recovery Mode?
Turn off the unit
Disconnect all the cables
Wait 30 seconds, connect only the PSU cable, and turn it on again
On the loading/splash screen, press and hold the “A” and “H” stomps
