@nanthil Thanks for the screenshot.
First of all, you need to install the ASIO drivers included with your audio interface. Check this link.
After you’re done with that, you can configure your audio settings. Select << none >> as the Audio Input Device and Audio Output Device, then switch to ASIO at the Audio Device type. Finally, select your audio device, sample rate and buffer size. Your Audio Settings should look like this:
- Audio Device Type: ASIO
- Audio Device: Focusrite USB ASIO (This can vary depending on your audio interface)
- Audio Input Channels: Input channel 1 or 2 (Just leave one input enabled)
- Sample rate: 44100 Hz
- Buffer Size: 128 Samples
If you encounter crackling noises and audio dropouts after using those settings, follow this guide to optimize your system.
