Hey there!
What Power Supplies all of you are using?
Im sitting here and struggle whit the standard wallplug. To my opinion the plug is flimsy and far away from the quality of the Quad Cortex.
I start looking around for some solutions and I have seen some solutions white CIOKS stuff.
Have some of you seen and tryed the Laney Mini-Laney PSU 12V?
It looks more reliable…
Other ideas?
Thanks for help an greetings from Cologne in Germany!
Hi @TheBeardBear87, and welcome to the community!
Many who are powering multiple components (pedal board etc.) are using the CIOKS successfully.
For a more robust replacement of the OEM PS, I was recommended the Globtek 12v 3a PS from DigiKey, in the US it was $24 shipped. Maybe DigiKey ships international or there is an equivalent vendor.
No worries!
One thing to note, the Globtek comes with a set of barrel tips, the QC uses the largest yellow marked tip but if you get this PS, just ensure your polarity is correct (center negative) with a digital multimeter before snapping the tip into place.
That’s great news! Can you put up a link to the PS you are referring to? I have found several power supply’s on Globteks website, but I don’t see one with three optional tips??
