Plugin Trouble shooting
Hi there, Im new to this forum so forgive me if this is in the wrong place.
Read below for in depth but the short of this is Update problems with the Archetype Plini plug in with Garage Band.
I purchased a Plini plug in in 2022. I had a few issues getting it linked into garage band to begin with but then everything was fine.
here’s the issues I had and fixed just so you know what Ive done again this time round (that isn’t working currently)
  1. I had to enable Audio Units in GB settings
  2. after seeing this message “can’t be opened because Apple cannot check it for malicious software.” I had to temporarily override the security settings
  3. I had to make sure that the plug in was in the right place ( library/plug-in/components as .components…)
So after doing all this everything worked. Fast forward to 2024 and I stopped using the plug in for about a year. Then I open up the plug in just last week and keep seeing this message “The Audio Unit “Archetype P” could not be loaded for your project and may need to be updated. Contact the manufacturer for an updated version or further assistance.”
So after some investigating I realize that my Ilok manager has not been updated and I also have not downloaded the latest version of the Plini plug in from the Nov 2024 update. So in order to make things as clear as possible,
I deleted every version of NDSP plug ins on my Mac, this included some not yet activated trials of other models (Cory Wong and others) and the current version of the Plini I was using from the beginning.
So once the GB Audio Units plug in page was clear, and the files removed I proceeded to
1.update the Ilok manager and activate the Plini license to this Mac book
  1. download the updated version of the Plini plug
  2. enable Audio Units in GB settings
  3. Override the security settings for the
“NSCreateObjectFileImageFromMemory-iY0xLY1u” file
  1. double check that the new plug in is being stored in the right place library/plug-in/components as .components…
the issue im having now is even after doing all that multiple times is this
this message is being displayed when I try to launch the Plini plug in in garage band no matter what I do " The Audio Unit “Archetype P” could not be loaded for your project and may need to be updated. Contact the manufacturer for an updated version or further assistance"
When I launch GB now it says "The file couldn’t be opened because it isn’t in the correct format. The file might be corrupted, truncated or in an unexpected format"
And "“NSCreateObjectFileImageFromMemory-N59kn1dU” can’t be opened because Apple cannot check it for malicious software. This software needs to be updated. Contact the developer for more information.****" Constantly comes up
as well as "A wrapper bootstrap error happened. This software cannot be loaded. Please contact the software publisher for support using this software."
I might add that the pill plug in works perfectly on its own when I just run it as an app.
Im really not sure what to do at this point.
Did you ever find a solution for this? Having the same issue with Nolly X
I have been having this issue for months now since the new Mac update awhile back. Has any found a solution yet?
Having the same issue here on my macbook pro 2019. Currently running sequoia 15.6, an update for Tahoe is here but i doubt it will fix this. Any news or updates?
My issue is with Mateas Assato Plugin
