Updating properties of AU Archetype Plini by Neural DSP…FAILED!
Hi there,
I’m unable to open Archetype Plini in Logic Pro X.
I was able to use the trial version, but after purchase, I activated it via the license key and upon rescanning with the plugin manager, everything gets validated successfully except the last line which says
updating properties of AU Archetype Plini by Neural DSP…FAILED!
And then the plugin doesn’t load.
How do I solve this issue?
Hey sorry to hear you’re having problems with plini. If you would, drop a line to support@neuraldsp.com with the issues you are having. Thank you!
