So far, to save rows and CPU, I send my gtr to my stage amp via FX Send 1 (the block is on the last row just before the amp capture / cab).
Please code Loop blocks to Send 1 & 2 + Output 3 & 4.
Have also the volume knob to be active on these blocks.
Saves rows, then we can use the volume knob to control output. (so far, volume knob not assignable to Send blocks)
I’d like to second this. In my case I use all 4 rows in my presets. I do stereo guitar + vocals through QC. Rows 1/2 are some pre fx, doubler, amps for left and right sides, output to Row 3, which has some post fx, sends 1/2 for stage amps, IR loader(ST), master eq, master comp, outputs to Out 1/2. Row 4 is dedicated for vocal chain and outputs to Out 4. So, I have Out 3 unused and unreachable, and I would like to output mono sum of row 3 there, for rare cases, when I have to go into into mixer or stage amp by mono cable, for those I have universal mono preset and is about to build a couple of summing cables, but being able just to plug into Out 3 and have my workflow unchanged feels much better.
I’d like to see the output blocks like this:
Auxiliary outputs:
Output 3&4
Output 3
Output 4
etc
For mono outputs I want them to be able to sum audio into mono signal for sending out into real world, but, I dont want them to break stereo inside QC chain
