Hi,
Like many before me, I’m trying to build a basic template for amp models and effects that sits within the external gear I plug my QC into. How to best route all this within the four lanes confuses the hell out of me.
The way I use my QC is as follows:
- Out 3/4 used to drive external power amps into a pair of guitar speaker cabs. Obvs I don’t use any speaker simulation or IR on these outputs, just a bit of EQ. I know, this is not really how you’re meant to use a modeller but I like the sound of the cabs I built.
- In the evening (or any of the other times I can’t play loud) I use headphones routed via Out1/2. This path needs an IR or speaker simulation.
- I have too much esoteric kit and still run external stereo effects in the effects loop so that takes up Send/Return 1 and 2.
I’d like to set up a template with a handful of slots before and after the amp model that then splits off through an EQ block to Out3/4 and an IR to Out1/2.
I’ve read horror stories about latency as soon as you include Row 3 and so wanted to try and achieve all this on Rows 1 and 2.
So, two questions:
- Is there really a latency issue related to use Rows 3 and 4?
- Ideally I’d use something like the preset below but assigning the output of Row 2 to Out1/2 and connecting the Mixer block on Row 1 to the Output of the Reverb block on Row 2.
Or, even being able to assign the output of Row 2 to be Row 3 would at least only incur latency on the headphone output but I don’t seem to be able to do that either.
Any tips gratefully recieved.
