can someone crayon talk this for me?
Hello old man ![]()
There is a thing called manual. Which explains the upload in a very simple way.
If you have further questions. Feel free to ask
Shut the front door, there’s actual instructions? All collated in a single document? That’s available for FREE??
Here I was with my QC opened up on my desk, trying to trace the circuit board to figure out how to use capture cloud…
well that was helpful… https://www.youtube.com/watch?v=2HZHbeSkGno
You upload presets and captures directly from the QC. When you tap on the preset name from the main display you’ll pull up the ‘Directory’. On the left are the ‘My Presets’ and ‘My Captures’ folders which will list your settings when pressed. For anything you want to upload simply long-press on the name and a ‘Copy to Cloud’ button will appear at the top. Drag the item to that button and it’ll upload right then.
Near the bottom of the directory is a section labeled ‘Cloud Directories’ where you can see everything you have uploaded. Below that is a section called ‘Starred and Shared With Me’ where you can see the items you’ve marked in the smartphone app for download.
