NOOB: MIDI Control - QC + H90
Hello
I have an Eventide H90 in effects loop 1 of the QC. I have set the H90 to MIDI channel 2. I want to be able to send a PC to the H90 when I select a specific patch on the QC.
I’ve set the ‘preset MIDI out’ to be send PC #100 to the H90 when patch 2A is selected, but the H90 doesn;t seem to hear the QC.
I could do this really easily with a Line 6 Helix Stomp + H9, it just seems really hard with the QC and H90.
Open to suggestions!
Have you turned off Midi Thru?
On the QC? Yes.
OK, I have fixed it. the QC is doing what it’s supposed to.
The issue was the H90: I was sending incorrect PCs based on what the manual was telling me. I tried different PCs and it worked instantly - so now the task I have is finding the H90 PC map, and/or understanding how it maps PCs to user lists.
You can only select presets from the currently selected user list on the H90, meaning you need to physically organise your presets in a single user list, ie USER LIST 2, then your PC# to send will be the same as what it is on the H90 (depending on what offset you have set - some units use 0-127, some use 1-128). Inotherwords, if you send PC#4 from the QC it should select preset #4 on the H90 - in the current selected user list.
