First, Joki and I are in touch over email (and his support has been excellent), but I did want to check if anyone’s run into the same issue using ANY volume pedal + QC in case this is an issue on the QC side
this is the original big mono volume pedal
The problem: the volume pedal introduced noise into my quad cortex. I didn’t have a ton of time to diagnose on stage but here’s what I observed:
- The noise was a loud static
- It changed volume in sync with the pedal’s position
- I could still hear the guitar as well, just with overlaid static
- The pedal made the noise with guitar, muted/guit volume pot off/no instrument/blank QC preset
Rebooting the pedal (unplug/replug power) fixed the issue. It’s permanently installed on my pedalboard so no jiggling/unplugging happening. Power supply is strymon ojai. QC power supply is stock.
the only difference between the stage and practice at home is I had output XLR 1 & 2 both plugged in; at home only XLR 1 was plugged in.
From what I understand this pedal doesn’t have advanced circuits that could fail in that way or that a reboot could plausibly fix. Maybe the problem is on the quad cortex side and rebooting the pedal was perhaps equivalent to plugging/unplugging the input?
Before I go tearing my board apart to diagnose I would love to hear if anyone else here has experienced something similar.
Thanks all,
D
