Booted up my QC for the at least the 100th time today and there’s no sound at all from any output. Worked fine yesterday, haven’t changed anything or even moved it about. Rebooted, five times, checked settings, everything and nothing works.
WTF is wrong with it? Really don’t trust this for gigs!
You may have already tried all this but here are a few preliminary suggestions. Volume/expression pedal (if you are using one) turned up, or preset tested without expression pedal? Main volume up? Check and reseat all connections and make sure they are in the output corresponding to designated output block. Swap out cables, guitar, headphones or amp/FRFR. Btw, is this happening on all presets? Hopefully you don’t have a hardware issue.
