No Sound when changing outputs
Strange thing going on here, but maybe i’m just missing something.
First: I’m using the QC for 2 years without bugs until yesterday.
I’ve setup the qc with my victory kraken (4 cable method), but there was no sound. I thought of having an issue with one of the cables but when i rebooted my QC it worked immediately.
Strange thing: The Output 3/4 (which were going into the input of the Kraken) were showing a consistent output signal without even playing anything, every other output + input showed nothing even when i played something - like a freeze / bug kinda thing.
When i started the qc later the day and rewired everything to my studio setup (just output 3+4 going to my Monitor Speakers) it happened again (no in and output signal), i had to reboot the QC, then it worked.
Did anything like that happen to you? I could swear i changed cables multiple times in the past while having the QC ON.
So i did open a support ticket for this case.
Happened again at yesterday’s show. Pretty annoing.
At home i only wire Out 3+4 to my studio monitors. Shutting down and booting it up works flawlessly.
At the show i plugged everything in for the use of the 4CM (PRE BOOT!). When i started the QC the input and output levels showed a freezed signal, no Sound at all. neither through the PA nor the Amp’s Cab.
I rebooted the QC several times, but it didn’t help.
Because i was anxious at this moment my IT-Admin background kicked it - i removed any cables from the QC (but the Power Cable), shut the QC down and powered it on again. THEN i plugged everything back on and it worked.
I hope this is an issue which WILL be resolved asap.
My workaround for the upcoming show next week will be booting the QC up without anything plugged in and wire everything up after booting successfully.
