No sound after CorOS 3.0 update
Hello all,
Loving the CorOS 3.0, update went fine and worked fine for a couple days, but now theres a recent issue that has arisen recently where i turn on the QC and there is no output. The QC is recieving input and signalling output, but there is no sound no matter which new 1/4" and XLR cable i use, nor which ever speaker i use. There is no Global muting enabled on any block as well.
The only fix i have found is restarting multiple times and eventually it will work.
Today however, ive restarted roughly 10 times and have no sound. This never hapened on previous firmwares.
This is really scary considering my band is about to embark on a tour across NA and i cannot have this happen in a live situation.
Has anyone else dealt with this since updating?
I haven’t heard or seen anything similar but definitely recommend emailing support@neuraldsp.com right away in case you need a hardware repair or related.
I’ve seen a similar report or two.
How old is it? Where did you purchase it?
No reply from OP so this will be closed.
