I want to know how to get my SP1 mission pedal to turn on the wah and then press the switch and control the volume of the amp block for solo boost. Does it matter which exp is chosen ? Or whether the bypass is switched on?
yes, you will want to assign XP 2 for the switch operation- the ‘bypass’ for both FX. Just make sure they’re set in opposite states (one off/one on) and you’re good for switching back and forth between them.
Then assign XP1 for the sweep on the wah and the gain on the amp (if you want to boost it that way)
here are more detailed instructions:
Frequently Asked Questions - Quad Cortex Wiki?
